| Implement Alley Discussion Forum |
Topic: JD 810 3/16 plow
[Return to Forum]
| Author |
[Modern View]
| RMOMN
01-10-2013 18:44:05
70.97.243.96
I'm looking at a 810 3/16 that doesn't have the tail wheel I'm planning on using this with a JD 620. What is the purpose for the tail wheel? |
| RMOMN
01-11-2013 14:32:36
70.97.243.96
Re: JD 810 3/16 plow in reply to RMOMN, 01-10-2013 18:44:05
| The plow does have a gauge wheel and a 801 hitch I believe is what he called it. This plow was used behind a JD 60. Would I still need the trail wheel? |
| AJB-830
01-11-2013 18:45:05
50.105.152.211
Re: JD 810 3/16 plow in reply to RMOMN, 01-11-2013 14:32:36
| Rmomn, If it was me, I would 1st try to locate a rear wheel before I purchased it. In my opinion, these plows don't work all well with an 801 hitch. But maybe with a real 3-point hitch, like on a 620, they might work better. I hardly used mine on the 70 and found a trailing 3 bottom 55 or 555 works much better. In my red clay land you could not pull a 3-16 with a 60 or 620. My 555 3-16 makes my 830 work in packed corn land. Al |
| Tyler-MO
01-11-2013 07:32:40
50.40.174.43
| | RMOMN, JD used these tail wheels to hold the rear of the plow up vertically and laterally to balance moldboard / furrow slice pressures. If you would intend on using one without a tail wheel keeping the plow pulling straight might be a real challenge. Later models of JD and other make plows that did not have a tail wheel utilized an extra long landside to alleviate the furrow slice 'pulling crooked' problem. You should be able to procrure a tail wheel from any newer style JD integral plow such as F110/ F120/ F115/ F125 that would bolt up to your plow just fine. One side note, JD used a 4.00x8 solid rubber wheel on the early 810 series plows whereas the later used either a 21" diameter stamped steeel wheel like the other guy posted or a 4.00x12" pneumatic rubber tire. Tyler in IL |
| Carlyle Hoffman
01-11-2013 04:14:58
74.71.111.250
| Its called a ROLLING LAND SIDE. Tends to steer the rear of the plow, also effects DEPTH and LATERAL sway.Nearly every mounted plow was provided one, with a few exceptions. |
| AJB-830
01-11-2013 07:19:00
50.105.152.211
Re: JD 810 3/16 plow in reply to Carlyle Hoffman, 01-11-2013 04:14:58
|  Every JD 810 or similar plow I have seen had a tail wheel. I would suspect someone removed it. Don't think it would be hard to find a tail wheel for it. Possibly someone converted a 4 bottom to a 3 bottom and didn't move the wheel. I converted mine from 4-14 to 3-14. But you could try using it without it. Al |
| BushogPapa
01-11-2013 10:10:09
173.88.51.117
Re: JD 810 3/16 plow in reply to AJB-830, 01-11-2013 07:19:00
| Without the tail wheel, you will need to extend the rear Landslide and add an adjustable "HEEL". Using a Gauge Wheel could control depth fairly well, but you need the extended Landslide, if you do not get the rear wheel assembly.. Ron. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
