Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: JD planter vs. IHC hydraulics
[Return to Forum]
the Unforgiven
01-09-2013 08:53:50
66.146.251.119
Do you have to do anything to the tractor, in this case a 966, to use the single hydraulic line for the lift and the markers? Seems more like an old one-way system? Can you just plug in one side and go?
[Reply]   [No Email]
gbs
01-10-2013 16:31:42
71.51.251.83
 Re: JD planter vs. IHC hydraulics in reply to the Unforgiven, 01-09-2013 08:53:50
all the 7000's i've used had 2 hoses for dual action,but they will work off single too,either way they work best if used with a float position valve so the drive wheels always stay in contact with the ground especially with hold springs on the planter boxes for no-till also when the planter is lowered the row markers will lower on their own without tripping the hyd.valve back to neutral
[Reply]  [No Email]
Loosehandle
01-09-2013 20:28:17
174.238.194.186
Yes,just make sure you get it down all the way.
[Reply]  [No Email]
IaGary
01-09-2013 20:06:16
108.160.237.250
I don't know for sure but are you sure that the markers aren't activated through that master cylinder and the two hoses are hooked to the master cylinder making it a 2 way.
Gary
[Reply]  [No Email]
the Unforgiven
01-10-2013 05:26:45
66.146.251.119
 Re: JD planter vs. IHC hydraulics in reply to IaGary, 01-09-2013 20:06:16
OK Gary, I will check that out, I knew they had some markers that were operated by the lift. The hydraulic hoses have not been fooled with, just wadded up a little.
[Reply]  [No Email]
JMS/.MN
01-09-2013 16:29:23
209.237.125.241
Check your Operator manual- some tractor companies recommend using a certain side for just one hose..........even tho either might work. JD is that way.
[Reply]  [No Email]
Bob Bancroft
01-09-2013 13:15:41
97.73.64.143
I am not familiar with a JD planter that only has one hose? What model is it?
[Reply]  [No Email]
the Unforgiven
01-09-2013 16:43:32
66.146.251.119
 Re: JD planter vs. IHC hydraulics in reply to Bob Bancroft, 01-09-2013 13:15:41
It's my "new" 7000 8rW, pull type, finger pick-up. The lift uses one hose running to a "master" cylinder, and the markers use a single hose too.
Now I must admit that I know very little about this planter, just got it unloaded and still setting it up, but I'm about sure that the lift had a single hose. Could very easily be wrong! Thanks guys!!
[Reply]  [No Email]
JMS/.MN
01-10-2013 10:26:43
209.237.125.241
 Re: JD planter vs. IHC hydraulics in reply to the Unforgiven, 01-09-2013 16:43:32
You can set it up with a separate hose just for the markers....nice if you want to control the markers separatly.
[Reply]  [No Email]
Bob Bancroft
01-09-2013 17:04:06
97.73.64.145
Nope, not familiar with that one.
I will add though- usually when you're running one way systems with a two way valve, they want you to have the capability to put the valve into "float", so you're not spiking pressure in the system by dead-heading one side of the valve all the time.
I initially asked because recent JD planters are apt to have an odd number of hoses. Mine has 5. Even my neighbors', which is still a finger pickup planter, has the extra "return" hose going directly into the tractor sump.
[Reply]  [No Email]
DeltaRed
01-09-2013 13:04:59
67.6.219.50
Yes,no problem.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
