Re: Advice on buying a backhoe
JD Seller
01-08-2013 06:36:31
Case are the easiest to find used parts for as there seems to be more of them parted out. Ford is the hardest to find parts for as there are not near as many ever made. JD and Cat will be the higher priced ones.
You did not mention your price range. That makes a world of difference. If your looking for some thing in the $5000 range you are going to have to get a real old Ford or Case to find anything that cheap. If you can spend $15,000 then you have a lot more choices.
Also it makes a difference how often you are going to use it. I started out with a three point mounted Kelly. I did not think we would use one much but I soon found out we used it quite a bit after we had one. So I sold the three point one and found an older JD 410. I have had it 15 years or so. It is has MFWD and a cab. It had 2500 hours on it when I bought it. At that time there was a bunch of them around used I was able to buy it for $17,500. Just a few years after that the building trades took off and it would have cost $30,000.
So the general economy makes the value of them go up and down as building demand cycles.
I remember reading thirty years ago how they where hard to find because the used ones where getting shipped over the Kuwait after the first Gulf War.
01-08-2013 10:00:17
 Re: Advice on buying a backhoe in reply to JD Seller, 01-08-2013 06:36:31
JD what year is your hoe???? I have a JD 410 1977 very low hours--just use for my own use.
THE QUESTION Could a 1977 410 JD have 4x4
Would I be able to convert mine to 4x4????
01-09-2013 13:34:12
 Re: Advice on buying a backhoe in reply to lenray, 01-08-2013 10:00:17
You'd be into a 'C' before you got MFWD on a Deere hoe. I think you'd also be well advised to stay in at least a 'C'... if not a 'D' series machine. Old 410's are starting to get parts obsoleted or you get relegated to A&I to find what you need. That's not an appetizing prospect.
JD Seller
01-08-2013 20:15:07
Mine is a 1989 model. I don't think they offered the MFWD until the mid 1980s. Yours does not have the right frame to have had a MFWD offered on it.
