Having trouble finding implement tires
Anonymous-0
Many pieces of my equipment (wagons, rakes, haybine, etc.) have older light truck tires on them. I think mostly 4 or 6 ply 15 inch ones. It seems most light trucks nowadays have 16, 17 and maybe even 18 inch tires and I am having a tough time finding used light truck tires that are 15 inch. Anyone else seeing this?
Yep, I have been hoarding 15" tires as I get my hands on them. Hard to find the truck tires for sure.
Kow Farmer
In my area the small size 15 like the 205 or 225 are easy to come by but if you want a 235 forget it. Watch Criag's list I see them from time to time there
Same here in Missouri. I just bought some at a local auction. There were lots of car tires but very few light truck tires. I was fortunate enough to wait and buy the LT tires. Mike
I am going to need good 215-75R-15 Light truck tires for my truck. Do you ever find any of those? Any used tires are hard to find of any size.
I have a local usde car dealer who puts his takeoff tires by the back gate, free for the taking. Been checking his supply regularly. 15 inch tires are getting few and far between. We have a couple SUVs that have 15's, and have been jealously hanging on to the leftovers. Lots of my machinery has 15 inch tires, need replacements regularly.
Couple places in town most likely have them on hand used. I know I have one or 2 laying around but then I have a lot of tires around
I wish I could either find some heavier 15s or 4 six bolt 16" wheels for my stock trailer. I blew one of those light tires today with a load on and tore the wires out for the electric brakes when the tread flapped around at 55 miles an hour.
Yup.
http://www.umequip.com/wheels/replacement/implement/
I hear Unverferth is making 6 hole implement rims for 17 inch tires, we'll have to convert to those some day.
--->Paul
Yes I ran into this same problem last year when I wanted to replace some 15" tires on a gravity wagon. So I bought new rims and re-used the 16" tires from the F250 pick-up that I had put new ones on. Wheels were about $90 each which included mounting my old truck tires. But my tire dealer said this will only work for a few more years as most 3/4 ton trucks now come with 18" tires. Al
Know what you mean. I am old enough to have come full circle, we cut spokes out of steel wheels anp put 16" wheels on then 15", in the 50s we bought wagons with 14" wheels, then back to 15", now 17" then you tell me we need to go with 18", I wish I still had the old steel tires,Dang Kids!
Just wish we were closer. A used tire and shipping would probably add up to what a new one would cost. And I have used all but 9 of those McCormick rake teeth and have place for them plus more and the others that you did not know what they were for are New Idea 3 bar rake teeth and I have that rake setting here just waiting for the weather so I can put them on.
I have a small utility trailer now that needs tires, and they are 14's. Just lucky I guess that I have a car with 14's that needs new tires, so my plan is to buy new for the car, then recycle two of the 4 for the trailer, and put the other two away out of the sun and weather for later. Not many cars with 14's these days, but this is a 98 model.
You want hard to find tires try finding 13 inch ones now days. I have 2 cars that run 13s and those you never find used
yep. I found some 18 inch implement pattern wheels, I think from 60"s John Deere combine, to put on the from of my loader tractor. The used load range E pickup tires cost $5 a pair.
Are those 6 bolt wheels?
I found 90's chevy 16 inch 1/2 ton wheels will bolt right on if the offset is compatible.
Here in the Pacific Northwest you can find all kinds of 15 inch car/truck tires this time of year on Craigslist. The down side is they are almost all studded tires with the studs worn off. Lots of tread left though on the tires though. The studs are kind of tuff to get out but they will come out. Many though just leave them in when used on farm equipment.
Slade I have found over the years that used car/pickup tire maybe cheap but they usually don't last very well. So I quit using them and just buy farm implement tires. They ride better on wagons and seem to last much better too.
Yes,they're 6 bolt. I've got one Chevy 6 bolt here but I haven't checked to see if it fits right.
The offset on the 90s vintage Chevy's is huge, so they didn't work for me on my trailer. Maybe you will have better luck.
never had problems finding implement tires, our dealer has a good stock of 9.5L and 11L 15 implement tires in stock.
