TractorLinks.com
Re: 3/16 plow JD 620
Leroy
01-05-2013 13:12:06
All the quick hitch does is move the hitch points further back, does nothing to work with the load and depth control. You would still need a connection to the top of plow mast to the quick hitch.
tomstractorsandtoys1
01-06-2013 07:43:47
 Re: 3/16 plow JD 620 in reply to Leroy, 01-05-2013 13:12:06
You don't get it and are not going to.The only way for you to understand would be to try it both ways with a semi-mount plow then you would see the diference.
BushogPapa
01-06-2013 17:23:30
 Re: 3/16 plow JD 620 in reply to tomstractorsandtoys1, 01-06-2013 07:43:47
Guess I sure don't see what you had a problem with...
I HAVE BOTH and use BOTH and don't NEED that upper-Link, with a Semi-Mounted F-145.. The F-145 Semi-Mount WILL pull down on the rear of the tractor, as Load increases..believe me... I do like to have a Gauge wheel at the rear Bottom, just to let it take care of that end..!!
Ron..
