Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: 3/16 plow JD 620
[Return to Forum]
RMOMN
01-04-2013 16:11:37
70.97.243.96
What plows should I look for that wear parts are still available and do a good job not loading up with trash?
[Reply]   [No Email]
IHCPloughman
01-10-2013 10:52:49
208.53.195.38
Re: 3/16 plow JD 620 in reply to RMOMN, 01-04-2013 16:11:37
Back to the OP's question: how 'bout a 55 or 555 trailer plow with HS bottoms?
Another note on quick hitches: you can't go out and buy a new quick hitch because it won't work for draft transfer. Every new quick hitch I have seen has the lower implement connection and the tractor lower link pin hole in line. The implement connection needs to be lower than the tractor pin so the implement draft is transferred to the top link.
I would think some draft sensing would make things go more smoothly. Imagine using only depth control and the plow hits a hard spot, weight is transferred off the front wheels of the tractor raising the front up a bit, weight is increased on the rear wheels and the tires squish a bit, all making the lower three point arms lower, which makes the plow go deeper. So the plow hits a hard spot, lugging the tractor, and then the plow dives deeper!
I picked up a Minneapolis Moline quick hitch (that's built properly) to use on my CIH 885 so I can pull a semi-mount plow properly. MM tractors in the 60's were top link sensing and required quick hitches for semi-mount plows.
  [Reply]  [No Email]
Dave Gunem
01-09-2013 07:00:03
174.124.120.225
I use a 1960 810A Special Trash plow [ 3 - 16 ] behind a 1960 630 and a 1958 620 LP and they handle it OK in most conditions except june plowing a dry hayfield . They can do it then but it slows them down enough that it makes the coverboards a decoration . This is of course a fully mounted 3-point plow and I have rock boxes on the front of these tractors that weigh 150# and I throw 3 100# slab weights in the box . That makes the steering ok and still leaves the traction ok . This is with 14.9 tires on the 630 gas and 15.5 on the 620 LP . Rollover plows on these tractors require much more weight in front but you probably aren"t talking about those .
  [Reply]  [No Email]
BushogPapa
01-04-2013 19:43:24
173.88.51.117
Looks to me that Shoupe has by far the best prices on New parts and will even ship Free, if you get enough parts..
If you have pretty "average ground", you can pull 3x16"..as long as you have good tires..
I do not think there is any problem pulling a "Semi-Mounted" plow.. I have successfully pulled my F-145 4x16" Semi in very hard plowing conditions with my 630 and while it was a maximum load in 2nd..the main place I had to have weight was on the front..about 300 lbs...New, Loaded 15.5x38" and 2 wheel weights on each side..
Weight transfer with a Semi not using the top link..??
The Front was real Light..I'd say it has all the weight transfer it needed..!!
3x16" should be a piece of cake...
I am cutting one F-145 4x16" down to a 3x16" Semi-Mounted, just for something different..
Either is good, the Fully-Mounted takes up less space, but will require some front weight to be safe while transporting on the road..
No reason to think about any 3x14"..it is not enough to even make the "Load-Depth" control active and operate correctly..
Ron..
  [Reply]  [No Email]
tomstractorsandtoys1
01-04-2013 18:47:37
64.136.27.162
If you want to stay with a Deere plow the F115-F125 would be a good match as a fully mounted plow and a semi-mounted would be a F135 or F145.The F115 and F135 have shear bolts for a trip and the other two have a safty trip.To use a semi mounted plow on a two cyclinder you will need to use a quick hitch because the 620 gets it's load and depth control thru the top link and not the bottom three point arms like a 3020 or other new generation row crop tractors.Oliver made some good plows as well.
  [Reply]  [No Email]
longmeadow farm
01-05-2013 05:54:21
72.224.6.238
Re: 3/16 plow JD 620 in reply to tomstractorsandtoys1, 01-04-2013 18:47:37
I often wondered about the use of a "quick hitch" to handle the top link load and depth control properly. I normally use a bottom link sensing tractor with my F145, However, I have been looking at using my restored 720 diesel for family plowing days, an annual tradition for us. My operators manual shows an arrangement for the JD 2020 tractors..I presume with top link sensing... Have you tried it? Thanks
  [Reply]  [No Email]
01-05-2013 08:57:02
64.136.27.164
Re: 3/16 plow JD 620 in reply to longmeadow farm, 01-05-2013 05:54:21
Dad had a 4bottom oliver on his 720 and it would not work right untill he went to a quick hitch.He had to be on the depth contol all the time.Deere mabe a hitch for the semi-mount plows to use the top link for the 2010 tractors.
  [Reply]  [No Email]
Leroy
01-05-2013 07:04:08
69.88.205.38
That is what I was refering to. And the quick hitch will not do what that does. It would just only hold up a top link but not do any good. For bottom link sencing there are one location of pins for the arms but when you go to top link sencing they are loacted lower than the bottom link setting and the mast for the top link works on a piviot that is over the pins for the bottom ling sencing and the piviot ov the mast is what controls the depth for top link use, at least that is the way it was on the M-F 4-14" semi-mounted plow but that tractor and plow are long gone as I am no longer farming as the farm is gone. There was an easy way to set the cross bar on that plow to match the correct wheel tread setting but here in northwest Ohio it was actually too much plow for the 63HP Ford, No way would it have pulled a 16" like other poster said he pulls with a less HP tractor and 50 mile away.
  [Reply]  [No Email]
BushogPapa
01-05-2013 17:22:57
173.88.51.117
Re: 3/16 plow JD 620 in reply to Leroy, 01-05-2013 07:04:08
For a 620/630 or 720/730, you HAVE complete control of DEPTH at ALL times, without the upper link...and YES, a 720 will Stroll with 4x16"...
Those are not puney little Shetland Poneys in a 720 D..
You have NO need to worry about a "Top Link", with the JD Semi-Mount plows...as long as the plow is adjusted correctly and the tractor has front weight and good traction..
Ron..
  [Reply]  [No Email]
BushogPapa
01-06-2013 12:23:20
173.88.51.117
Re: 3/16 plow JD 620 in reply to BushogPapa, 01-05-2013 17:22:57
I was looking at a video on Youtube, with a 720 on a F-145 and 4x14" and it sure had all it could handle in 2nd..but he was plowing too deep for a 14" plow and didn't have enough traction, either..
I am beginning to feel a 16" plow doesn't pull very much harder than 14", when plowing 7" deep...
Plus, the 16" will not plug nearly as often..
I know..that does not mean I think a JD"B" would pull 2x16"..I KNOW they won't.. but, 3x16" is "Almost" as much plow as 4x14" and they pull a lot easier...
Ron..
  [Reply]  [No Email]
Leroy
01-06-2013 07:08:09
69.88.205.38
I agree with no need for a top link as I found out the outfit I had worked better if I did not try to use it. Other than that was what I said that a 620-630 in my ground would not pull a 4-16" plow, 3-14" yes and probably a 3-16" but not a 4 bottom. A 720-730 should handle the 4 bottom plow with no problems.
  [Reply]  [No Email]
BushogPapa
01-06-2013 12:15:47
173.88.51.117
Re: 3/16 plow JD 620 in reply to Leroy, 01-06-2013 07:08:09
I agree completely...there ARE soils (and Conditions) that will make all kinds of different loads on a plow...
My time at the "Plow Days" was probably not all that typical...
I had just re-built this 630 with New Mains and rings and a VERY GOOD Valve Job that NASCAR would envy...along with New 15.5x38", LOADED, 3 wts on the left and 2 on the Rt and 300 on the front..
This was NOT any more than it needed, either..!!
BUT, it DID pull it and over 7" deep in established Alfalfa and Jack Wax..
IT was every bit it could muster (900 RPM) in 2nd, at times..!!
Sure seemed to shake the very Ground..!!
What a HORSE..!!!
My 720, with 300 lb on the front and New 15.5x38" and a couple wts on each side walks right along with that F-145" 4x16 (here) in 3rd, 7+" deep...sometimes lifting the front..!!
It's not an "R", but holds it's own...!
Ron..
  [Reply]  [No Email]
Leroy
01-05-2013 05:48:33
69.88.205.38
The F145 had a top link sencing unit avaible as did other makes like the Massey Ferguson that I had. Even tho I had it and the tractor a Ford 5000 senced from the top link I lsually kept it in position control instead of using the draft control and top link senceing. Could get better depth control.
  [Reply]  [No Email]
01-05-2013 09:02:48
64.136.27.164
Re: 3/16 plow JD 620 in reply to Leroy, 01-05-2013 05:48:33
What you need the quick hitch for is more depth control than weight transfer.With perfect conditions(level field and all same soil type) it is not as much of an issue.If you have any hills or soil changes you are constantly moving the three point lever for depth control.
  [Reply]  [No Email]
Leroy
01-05-2013 13:12:06
69.88.205.38
Re: 3/16 plow JD 620 in reply to tomstractorsandtoys1, 01-05-2013 09:02:48
All the quick hitch does is move the hitch points further back, does nothing to work with the load and depth control. You would still need a connection to the top of plow mast to the quick hitch.
  [Reply]  [No Email]
01-06-2013 07:43:47
64.136.27.164
Re: 3/16 plow JD 620 in reply to Leroy, 01-05-2013 13:12:06
You don't get it and are not going to.The only way for you to understand would be to try it both ways with a semi-mount plow then you would see the diference.
  [Reply]  [No Email]
BushogPapa
01-06-2013 17:23:30
173.88.51.117
Re: 3/16 plow JD 620 in reply to tomstractorsandtoys1, 01-06-2013 07:43:47
Guess I sure don't see what you had a problem with...
I HAVE BOTH and use BOTH and don't NEED that upper-Link, with a Semi-Mounted F-145..
The F-145 Semi-Mount WILL pull down on the rear of the tractor, as Load increases..believe me...
I do like to have a Gauge wheel at the rear Bottom, just to let it take care of that end..!!
Ron..
  [Reply]  [No Email]
stanhoist
01-04-2013 18:08:33
74.33.92.152
IH #70
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
