What IHC disk is this?
Jason S.
It's an old pull type that was given to me. I found some IHC markings on it but I don't know what model it is. Believe it or not it cuts better than the two 3pt disks I have.
i have one just like it that needs a bearing housing. have been looking for a housing, but haven't found one yet. it also works better than my 3 pt disc.
I have no idea but have one just like it. Great disk. My Dad bought it at an auction at least 50 years ago.
Can you post a picture of your bearing housing? I might have one I can spare. I been cleaning up junk and had 1 disk someting like this almost complete and several disks in parts. I saved almost all the parts hoping to put together a small tandam disk with tires but you can only use so many bearing housings. One thing I notice different is the spools that go in the housing but if the bearing housing works chances are the spool for the housing would fit the square shaft on any disk.cleddy
measure the spacing between the blades and post it. Could be different on front and rear but most likely the same but 9A and 10A have different spacings
