John Deere Sickle Bar Mower
ErnDog50
I have a John Deere sickle bar mower currently attached to a 1959 John Deere model A. I believe the mower is a #5 or a #8 but I don't know for sure. How can I identify the model of this mower?
No sure how you would know if there is not a tag still on it other then maybe with a picture. I rebuild a JD-#9 this last spring and have it on a D-17
If I remember on the #9 it is in the area of where the PTO shaft goes to the bearing housing area. I'll be out there in the near future and try to look to be sure
On the #9 the tag is as your standing behind it straight back from the PTO shaft as it goes into the gear box. The #9 is a 3 point sickle mower with a pitman drive for the bar.
Easiest was is to look at the upper cover on the housing.
The photo below shows the upper cover for the #5 mower.
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/John%20Deere%20Equipment/Power%20Mower/?action=view¤t=IMG_3345.jpg" target="_blank">
IMG_3345.jpg" width="650" border="0" alt="IMG_3345
</a>
The photo below shows the housing and frame.
<a href="http://s200.beta.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Power%20Mower/TM-20-1_zpse18ebd94.jpg.html" target="_blank">
TM-20-1_zpse18ebd94.jpg" width="650" border="0" alt="TM-20-1_zpse18ebd94"
</a>
<a href="http://s200.beta.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Power%20Mower/IMG_0753.jpg.html" target="_blank">
IMG_0753.jpg" width="650" border="0" alt="IMG_0753"
</a>
Hope this helps.
My sickle bar mower is a #5 based on the fact it has an angle frame and the shape of the gear housing. I am looking forward to getting it restored and cutting a little hay with it. Thanks for all of the valuable input.
