TractorLinks.com
Blackhawk corn planter
JD Seller
12-29-2012 00:24:45
My Great Uncle had a three point lift BlackHawk corn planter. He planted two 30 rows with it. He usually only have 25 acres of corn and maybe that much in soybeans but that sure would have seemed slow when planting.
My question is about some history of that brand of planter. I am trying to get it bought back from the fellow that bought it at my uncle's sale.
My Uncle's was not the only one that was around here. Several other guys had them. I am sure this one was a factory three point lift one. I know that BlackHawk made horse drawn planters as well.
clevenger
01-23-2013 21:14:34
 Re: Blackhawk corn planter in reply to JD Seller, 12-29-2012 00:24:45
I also am somewhat near kalida and have a 135t blackhawk planter that i plan to restore. I am looking for seed plates and fertilizer box parts and an operators manual. I would appreciate an email with any info. Thanks in advance
clevenger
01-17-2013 14:52:37
JD Seller
12-30-2012 08:05:40
[quote="Art Massing"](quoted from post at 02:54:03 12/30/12) Seller,
I"ve attached a couple of pictures of the 2-Row Blackhawk corn planters that I"ve found over the years. I believe that using both, I can make one that works!
I also have a few plates but they are hard to find in my area (third picture; bottom group).
My Dad used a 4-Row, pull type Blackhawk corn planter for years.
Thanks,
Art
The one I am trying to get boughten back looks like the one in your pictures that still shows some paint.
I also measured my Uncle's cultivator. He did have the planter set down to 30 inch rows. HE very well have modified the planter to get it that narrow, He would a real crafty on changing things.
He shorted his JD manure spreader to make it work better with his smaller tractors. Get me in trouble when I posted on here how small it was. LOL
He made a Hume reel for his AC 72 pull type combine. Used a bunch of boards and cables to make it work.
Art Massing
12-29-2012 17:54:03
Seller,
I"ve attached a couple of pictures of the 2-Row Blackhawk corn planters that I"ve found over the years. I believe that using both, I can make one that works! I also have a few plates but they are hard to find in my area (third picture; bottom group).
My Dad used a 4-Row, pull type Blackhawk corn planter for years. Thanks,
Art
jimont
12-29-2012 12:32:11
Our first planter was a two row Blackhawk set for 36" rows. Planter was purchased from a Cockshutt dealer in Hagersville Ont.got it cheaper because we set it up ourselves. We are about 30 miles from Brantford Ont. home of Cockshutt
J. Schwiebert
12-29-2012 07:39:37
I have some information on the Black Hawk. They were part of Ohio Cultivator Company out of Bellevue Ohio. Send me a snail mail address and I will make you a copy. They were very popular planter in this area.
maxwell99
12-29-2012 07:31:03
JD,
I have a Blackhawk corn sheller, hand crank,
reason I bought it was because of the name.
Chief Blackhawk, Read up on Chief Blackhawk, he was a famous Indian warrior and Chief
I understand he was one of the first Indians that lead his people to fight back against the white man as they tried to take his land.
He was a great Chief and leader of his people, again I bought the old sheller because it has his name on it.
I to will fight as he did, if the man tries to take my land and the way its going i may have to.
Good luck with your planter, fix it up and use it, think of Chief Blackhawk protecting his people and land, each time you use it.
Greg K
12-29-2012 06:12:21
They were somehow related to Cockshutt company, but I don't remember how(will ask dad today). I have never seen a 3 point Blackhawk, if you get it post a pic it would be nice to see. Dad has one of the 2 row pull type planters and a few other implements along with some E-3 and E-4 tractors that he plays with yet.
Leroy
12-29-2012 05:58:46
Would you like a copy of the operators manual for that planter? If so I will make a copy and send it to you snail mail. That is assuming it is the ground drive model. It will take me a while to find by manual. A friend has 2 and I know where anouther is in the junk pile. Last summer I rebuilt the tractor drawn 2 row pull type and boy what a job, was not about to tackle the horse drawn one as for what I could get for my time I had too much other machinery to get ready for operation. Those 2 plus one other are avaible for sale now yet by the dealer I rebuild machinery for. Then there was the PTO powered model that was made for the 9N Ford and it kept running with the planter raised unless yoy thru the PTO out of gear to turn on the ends. Later they made a different PTO adapter that would dissengage the planter operation when raised. The friend that has those 2 and both slightly different also has a PTO powered unit on a 540 Cockshutt tractor and he has both the 2 & 4 row later versions from Cockshutt. The first Blackhawk 4 row were a pair of 2 rows with a special hitch to pull them. But I thinl you might be mistaken on being 30" rows as they only set down to 38" and up to 44" rows. The one I did redo he wanted it set to 30" but not possible and I got it to the 38" that is the narrowest. The friend has the book for the PTO powered planter. They were made at Belleview Ohio
J. Schwiebert
12-29-2012 07:42:43
 Re: Blackhawk corn planter in reply to Leroy, 12-29-2012 05:58:46
Leroy: You are not too far from me either since you said you were within 30 miles of Kalida or Delephos.That distance works for me as well. I have a Black Hawk planter Test Stand. How can I contact you snail mail wise as well. I would like a copy of the operators manual as well. I also may need a couple of parts. Thanks. J
Leroy
12-29-2012 17:54:24
 Re: Blackhawk corn planter in reply to J. Schwiebert, 12-29-2012 07:42:43
John, we have met before. Do you remember about talking with the Fisher boys a few year ago about putting on a Perkins engine seminar at the Buckeye show. I was with Ron at the VanWert show when he was talking to you about it. My address is Lester Helmlinger, 10622 Ashburn Rd., Wapakoneta, Oh. 45895. I either do not have the capablities for emailing things like that or if I do have then I have no idea how to do it, That is why I have to get copies made and mail them out. You know Dick Alexander, his wife is a cousin of mine and at one time I know he had a part of the test stand. As for parts I do not know where to get any, what I needed for that planter I made my own. It will be a while before I get a chance to hunt for the book. I think you are up close to Toledo. My hearing is to the point that I cannot reaonably use a telephone anymore so do not give out a number.
TWheat
12-29-2012 04:08:39
I remember an old 2 row horse drawn planter that Dad put a tractor tongue in. I had to ride it to raise and lower it and lift and lower the row giudes. I may be remembering it wrong, but remember it as being a JD BlackHawk. Did a good job for that day and time.
60 acre hillside
12-29-2012 05:01:47
 Re: Blackhawk corn planter in reply to TWheat, 12-29-2012 04:08:39
I had a two row horse drawn Blackhawk converted to three point. I think Blackhawk was in some way related to the Cockshutt company. I still have one of the plates in my collection. The plates were just a ring about the size of a JD plate but had the center all open.
