TractorLinks.com
Re: PTO shaft Length
Don-Wi
12-23-2012 14:00:16
I was always under the impression that the 2 halves should be the same length, so I would suspect if you made the front the same length as the back 1/2, you'd be set.
Donovan from Wisconsin
hayshaker5
12-27-2012 05:41:52
 Re: PTO shaft Length in reply to Don-Wi, 12-23-2012 14:00:16
Thanks for all the info. I will try these suggestions.
Tx Jim
12-24-2012 03:44:46
Doing as I described above the shafts would be close to the same length and would be the same with an Equal Angle hitch.
