Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: More pictures of the oliver rollover after adjustments
allen in texas
12-23-2012 07:49:48
Ok, this plow does have the holes for 14,16 and 18 inches. To make the adjustments (the way it is designed to be made) only the front and rear bottoms are moved. In my case I couldn't get the bottoms to fit my tire spacing so I moved the front bottom to the holes for the 14 inch spacing but I put them INSIDE the holes and that moved the front bottom 8 inches toward the center of the plow. I have to drill two additional holes to bolt the bottom to the frame. The middle bottom was moved to the inside holes also so I have to drill holes for it also. that move it 4 inches toward center. I left the rear where it was. I think another picture is in order. BRB
allen in texas
12-23-2012 07:58:14
 Re: More pictures of the oliver rollover after adjustments in reply to allen in texas, 12-23-2012 07:49:48
These are pics of the holes of the middle bottom. it is not supposed to be moved but I did it.
Hope this clears it up.
This post was edited by allen in texas at 08:00:49 12/23/12 2 times.
DeltaRed
12-23-2012 10:33:45
 Re: More pictures of the oliver rollover after adjustments in reply to allen in texas, 12-23-2012 07:58:14
Allen,fix/replace that bent bolt on the standard.that helps hold things together.For shear bolts'use grade 5.use a 'nylock'nut on it.they will come loose otherwise and shear faster because the beam/side plates will tend to separate if not kept tight.
DeltaRed
12-23-2012 10:40:53
 Re: More pictures of the oliver rollover after adjustments in reply to DeltaRed, 12-23-2012 10:33:45
I would buy shear bolts a dozen or so at a time.I mounted a small toolbox on the 'headstock'.kept bolts/nuts;wrench,ratchet/socket;tapered punch;hammer,etc.Carried a sledgehammer in the cab.Even when the 'tripped' bottom was returned to 'home',it always require a few raps with the sledge.
allen in texas
12-23-2012 17:51:02
 Re: More pictures of the oliver rollover after adjustments in reply to DeltaRed, 12-23-2012 10:40:53
Ok replace the shear bolts. got it. Grade 5 and nylocks Got it!
Got the cylinder, hoses and couplings today. still need a restrictor. Getting there.
allen in texas
12-23-2012 08:02:10
Here's a pic of the front bottom.
This post was edited by allen in texas at 08:05:22 12/23/12 3 times.
Copyright © 1997-2015 Yesterday's Tractor Co.
