Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: PTO shaft Length
Tx Jim
12-23-2012 04:04:23
Fairly simple to ascertain the correct length. Just hook your 990 to your tractor,turn tractor 90 degrees to cutter with NEW(used) shaft installed on tractor then set the 2 pto shafts(one installed on tractor pto & 990 shaft) side by side and cut to correct length. At the 90 degree turn the shafts will never slide any closer together than they are right then.
BushogPapa
12-23-2012 09:51:18
 Re: PTO shaft Length in reply to Tx Jim, 12-23-2012 04:04:23
Unless the tractor's front is heading up-hill..
Give it a little more slack..
Ron..
Tx Jim
12-23-2012 10:03:38
 Re: PTO shaft Length in reply to BushogPapa, 12-23-2012 09:51:18
Ron
The hill you refer to would have to be a lot higher than I would want to drive a tractor up :wink:
BushogPapa
12-23-2012 10:21:52
 Re: PTO shaft Length in reply to Tx Jim, 12-23-2012 10:03:38
Ha..yea.. but ya never know about crossing uneven ground...!
Today's larger equipment won't give much..just breaks something..!
Ron..
Copyright © 1997-2015 Yesterday's Tractor Co.
