Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Re: wagon hoist questions
[Show Entire Topic]  [Return to Forum]
paul
12-19-2012 10:39:31
66.60.223.232
I've seen some that were entire frames the size of the wagon box with a cylinder.
I've also seen the ones that are just barely bigger than the cylinder, with some steel that attached to the front bolester and front stringer of the box. I suspect this is the type you are talking about.
They should handle pressures up to 2500lb hydraulics, so should stand most new tractors.
Typically they bend the running gear middle member before anything else. They are hard on a weak running gear.
You could Tee 2 of them together, but this would work opposite of what it appears you are saying, it would run slower but lift twice as much, and be 4 times as likely to damage something. Also most want to be centered on that middle pipe of the running gear, they wouldn't fit right side by side unless you fabricate more. And, if you loaded your wagon off-center the light side would go up more, causing stability and twisting issues - can be compensated for but the hydraulic connection becomes much more complicated. By teeing them together you still would have full hyd pressure to both hoists, the oil would just be 1/2 as fast.
So - you can double them, but I don't think you'd ever want to unless you had a very strong running gear and box with extra fabricating?
--->Paul
[Reply]   [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
