Help identifiying this disk?
mcclaar
New User
Anyone know what brand this disk might be?
That is a case disc. Don't know which particular model, would depend on whether it has bushings or bearings on the gangs.
That's a CASE model S or SA. S had iron bearings, SA had ball bearings. They are basically a clone of an IH #37, but older. I have a 10' "SA108" and I use it every year works good.
At first I was going to say IH#37...But a closer look at the 6bolt hubs and the hitch assy.,I agree-Case.Look for some logos on the castings.The Case eagle or the IHC circle.....
Can anybody tell me what colors it should be?Maybe someone can point me to a picture of one?
Again thanks.
The color will depend on the age and model. Could be all flameau (case red) with yellow scrapers and wheels and hubs, or flambeau with green gangs and lift. I think some of those had yellow scrapers and wheels and hubs too.
The one I'm using is one of the last made and it's all flambeau red with desert sunset wheels and scrapers.
At first glance it looks like a 37... but on closer inspection, it clearly isn't.
I don't know what it is tho...
Rod
So Case had a green color as well? What did they call that?
Mine has some green on the hitch so I believe the color scheme looks like the one in the picture 1031D posted
Yes a Case. I bought one and in checking out new
parts was told it was built around 1958 and parts
are available. The one I bought is a 9' finishing
disk with articulated bearing holders. I had do some
weld repairs on the swivels because they were worn
some but a good disk. Maybe the IH#37 is a clone of
the case.
