Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: JD-327 Square baler.
rrr_ranch
12-16-2012 17:25:21
Well sir: I can run the baler and put out a pretty nice bale. The bar has never been moved out of field position in 20 some odd years, and removing the pin dosn't work. So I just was asking in case there's some little thing I'm missing. Thank you
Tx Jim
12-17-2012 04:43:55
 Re: JD-327 Square baler. in reply to rrr_ranch, 12-16-2012 17:25:21
rrr_ranch said: (quoted from post at 21:25:21 12/16/12) The bar has never been moved out of field position in 20 some odd years, and removing the pin dosn't work. Thank you
Since it hasn't been changed out of field position in around 20 yrs I'll bet the telescoping shaft is rusty and you'll have to heat it with a torch & lubricate it so it can slide. Parts key #7 is stuck inside parts key #9. You cam remove parts keys #13 and slide the shield(parts key #8 or 19) forward for am inspection. If this isn't the problem then I'd suggest looking at the rear pivot area of the tongue.
This post was edited by Tx Jim at 04:53:09 12/17/12 3 times.
