TractorLinks.com
Re: JD-327 Square baler.
JMS/.MN
12-16-2012 16:23:33
Do you mean the front hitch? Adjusting between road travel and field use?
rrr_ranch
12-16-2012 16:46:10
 Re: JD-327 Square baler. in reply to JMS/.MN, 12-16-2012 16:23:33
Yes sir that's the one. It seems to be locked in the field position and I can't budge it but it's loose if you shake it. Just won't swing straight ahead. Thanks for the reply
Cliff Nelson
12-17-2012 05:38:21
 Re: JD-327 Square baler. in reply to rrr_ranch, 12-16-2012 16:46:10
If it's loose but won't swing it could be the pto shaft as Jim said. Try removing the front pto support from the tongue and try to swing it then. Our 346 has worn the pto shaft slide so it catches if stopped with pressure on the driveline. Acts te same way when trying to cross over to transport position.
JMS/.MN
12-16-2012 17:48:11
I"d jack up the front of the baler frame, unhook from the tractor, and try to move it. That long in position? Maybe pivot is rusted solid.
rrr_ranch
12-16-2012 17:56:56
 Re: JD-327 Square baler. in reply to JMS/.MN, 12-16-2012 17:48:11
I have tried that and I'm afraid your right. Years back I saw my brother try to back up the tractor and swing it but that didn't work either.
Thanks again
