IHC, Four Bottom Plow??
daynee
This is an IHC plow made in the 1940's what im not sure about is what No. or model the plow is?
This plow also has a hydraulic lift which im not sure if it's factory or just some farmers add on?
Any help would be great!!
Thanks
dayne
Can't help you with a model number but that hydraulic lift is factory. Dad had a 3 bottom with that type of hydraulic lift assembly.
Yes that is factory hydraulics, but was added to plow. # 8 IHC They were built from 1927 to 1961. I have manuals for plows for sale. Thanks Question call Me Steve 419-618-0017
What IH tractor would this be pulled with, in the '30's and '40's..??
W-9..??
There were no Large IH tractors near us, never saw them "in the field", working...
Ron..
Around here that would be the right size for a W9. They use to sell kits you could retrofit an older clutch lift plow with hydraulics just like that ome is. They still retain the clutch so you still could use it if you had to. I had a 3 bottom that I used to use either way I would use a turnbuckle to set the depth in place of a cylinder.
