TractorLinks.com
Re: Don't think I'll get a chance to test the plow....
Aaron SEIA
12-11-2012 15:34:06
Plow it in the snow. If it's not too wet underneath it'll go ok. The snow ill be a blanket keeping the ground from freezing.
AaronSEIA
casenut1
12-11-2012 20:04:28
 Re: Don't think I'll get a chance to test the plow.... in reply to Aaron SEIA, 12-11-2012 15:34:06
plowing under snow puts nitrogen in the ground.
Dalet
12-11-2012 21:37:45
 Re: Don't think I'll get a chance to test the plow.... in reply to casenut1, 12-11-2012 20:04:28
Thats what I was going to say! My Granddad always said that an inch of snow on spring grain is the same as a ton of manure. Not sure if its the same, but it's beneficial I am sure.
Crazy Red Power in SE-WI
12-12-2012 13:36:00
 Re: Don't think I'll get a chance to test the plow.... in reply to Dalet, 12-11-2012 21:37:45
Never heard about nitrogen from snow before & plowing under snow was a vague idea at best. Glad to have learned something new today.
Thanks Guys!
Mike
RedRoundhead
12-12-2012 18:02:20
 Re: Don't think I'll get a chance to test the plow.... in reply to Crazy Red Power in SE-WI, 12-12-2012 13:36:00
You should be out plowing right now! :-)
I have done the chain thing in the past as well; works good.
There is alot of nitrogen in rainwater, so therefore in snow, too. We have been lucky; it has been a mild, mild "winter" in WI this year.
If you get cold, you can make a real cheap "windbreak" from an appliance box. An empty appliance box, that is. I did that one winter,for the H that I had, for which I used to plow snow. I had just gotten a new refrigerator, and with some tape and a utility knife, I stuck that empty box on the H. Even had a door in the rear! I wish I had taken pictures; it looked ridiculous! I had a warmer time plowing snow that year though. It helps! A bit of a fire hazard, so be warned!
Best of luck!
12-12-2012 18:57:09
 Re: Don't think I'll get a chance to test the plow.... in reply to RedRoundhead, 12-12-2012 18:02:20
I agree! I should be out plowing. :v) My chains did not turn up in my search this afternoon/evening. What was supposed to be chains for my tractor, turned out to be chains for the Ford AA truck I had. Might have loaned them out to my uncle. I think some of his Deere B's are on 11.2x38 tires. I'll have to pay him a vistit in the AM.
There is a windbreaker around here that came with my Grandpa's H. It's an F&F job, but, just like your box windbreaker (amusing/good thinkin'!), it keeps a majority of the chill out. I'll have to see If I can piece it together tonight, yet.
Thanks,
Mike
super99
12-14-2012 16:10:34
 Re: Don't think I'll get a chance to test the plow.... in reply to Crazy Red Power in SE-WI, 12-12-2012 18:57:09
When I was a kid, the guy I helped had a 67 Ford 1 ton truck with duals on the rear. He had a set of chains to get around in the winter. For tough fall plowing, he would hook both chains together and put them on the land wheel on his JD 4010 with 15.5x38 rear tires. Worked good. Chris
