Yesterday's Tractor Co.
Shop Now View Cart
Re: JD Drills
12-10-2012 06:46:09
It depends on what you want to plant. The 8300 has more depth control and a press wheel to firm the soil around the seed but plants in 10" rows. The 10" rows are good for soybeans but to me not the best for wheat. The 8200 you can plant just about anything in narrower rows as well as grass seeds but you just dont get the depth control as the 8300. I have an 8300 and like it for beans but for wheat I would like to have an 8200 to plant with. If you grow wheat and bale the straw I would use the 8200 for better straw quality. Bandit
Tx Jim
12-10-2012 09:13:12
 Re: JD Drills in reply to Banditfarmer, 12-10-2012 06:46:09
You're reading something from Earl's post that I don't see that deals with 10 inch rows. He stated he had a 10 ft 8200. The double run drill will plant seeds more precisely but is more complicated to set than a fluted feed drill. I've always heard bigger is better so I'd go with the model 8300 drill.
Mike Aylward
12-10-2012 11:08:19
 Re: JD Drills in reply to Tx Jim, 12-10-2012 09:13:12
Banditfarmer is right on this one. The 8300 drills with the "Tru-Vee" attachment were a 16x10 drill. They were only available in 10" spacing. Mike
Tx Jim
12-10-2012 12:24:08
 Re: JD Drills in reply to Mike Aylward, 12-10-2012 11:08:19
Mike Aylward said: (quoted from post at 15:08:19 12/10/12) Banditfarmer is right on this one. The 8300 drills with the "Tru-Vee" attachment were a 16x10 drill. They were only available in 10" spacing. Mike
I'm curious how you know the drill in question is a Tru-vee instead of one of these options from Earl T's original post???
I guess the farmers in N. Texas were too poor as I've never personally seen Tru-vee disk openers on a grain drill.
This post was edited by Tx Jim at 12:39:32 12/10/12.
Mike Aylward
12-10-2012 13:43:57
 Re: JD Drills in reply to Tx Jim, 12-10-2012 12:24:08
Jim, I suppose I do not know 100% for sure. When Earl mentioned his drill had gauge wheels and press wheels like BF I assumed it was a Tru-Vee drill. Perhaps I presumed too soon. These drills were very popular in the late 70's and early 80's in this area to plant soybeans. They mimicked the 7000 planter depth system and worked fairly well. They only came in 10" spacing to allow clearance for the depth gauge wheels. Conventional depth bands and press wheels, while not unheard of, were not common, at least in this area. Mike
Earl T
12-10-2012 17:36:08
 Re: JD Drills in reply to Mike Aylward, 12-10-2012 13:43:57
Hey guys I posted a picture of the drill setup in the implement photos under 8300 drill. I have never been around one that has had these options on it. I will mainly be using it for wheat and some soybeans. The thing that makes this a little bit of a decision is that road travel is difficult with the wheels to the outside. So just seeing if you guys think the options this one has outweights the cons of the width. Just to place myself I am in northern Indiana.
12-10-2012 19:34:44
 Re: JD Drills in reply to Earl T, 12-10-2012 17:36:08
Earl I looked at the photo and its a tru-vee set up and is a 16x10" rows. Now if you are moving it on the road alot or going through small gates then the 8200 is the drill you need. The 8300 holds about 36 bu and with its set up will plant beans with the best of them. But its like I said before its not the best for wheat. If it was me I would stay with the 8200 just for the fact that you are planting both wheat and beans. Bandit
Tx Jim
12-11-2012 03:46:12
 Re: JD Drills in reply to Banditfarmer, 12-10-2012 19:34:44
Sometimes it's better to be "lucky" because as the photo shows you were right. I guess this gets back to the old saying "a photo is worth a 1000 words". The only thing drills were used for in my neck of the woods was to plant small grains or Sudan so therefore no Tru-vees were ever sold here.
