Yesterday's Tractor Co.
Shop Now View Cart
Re: Can you suggest how I adjust this Disk set..
Case Nutty 1660
12-09-2012 15:22:28
I have two of this type "Offset Disc's", the more angle you set them at the more aggressive they will cut, in the straightest position they are for transport and will not cut all all just roll, as to the comment they are only for "worked ground" that is not the case at all for my two any way they will work up sod if need be just not in one pass, it is best on them to turn to the left when doing a sharp corner as they will dig in harder and it will put extra stress on the front RH disc blades cnt
Case Nutty 1660
12-09-2012 15:35:18
 Re: Can you suggest how I adjust this Disk set.. in reply to Case Nutty 1660, 12-09-2012 15:22:28
here is a shot of one mine a "CO" Case one a dam repair job I did last year it is a 6' wide unit, I was using it to chop and mix the "chunky" dirt and also it mixed the different types of soil I used to make the repair stronger, hope you don't mind I threw in a couple to explain the job a little better cnt
