TractorLinks.com
Re: Can you suggest how I adjust this Disk set..
Graham of New Zealand
12-09-2012 14:01:50
Not so sure aboiu the setting although I think it would be mainly only to make them track in the right alignment. But as for not penetrating I have used this sort of discs for 60 odd years and they are only designed for worked up ground, like from ploughing or heavier discs. If you try to use tandems for first cut work you will break blades and wreck the frame
Leroy
12-09-2012 15:34:37
 Re: Can you suggest how I adjust this Disk set.. in reply to Graham of New Zealand, 12-09-2012 14:01:50
They are designed as a primary tillage tool. Years ago the first one I ever saw when the neighbor bought a new John Deere 70 tractor he bough one and got rid of the moldboard plow, used it for all the heavy tillage.
