Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Advice on rusty slotted head screw removal on a 14 T baler
[Return to Forum]
david1
12-05-2012 09:05:21
184.5.147.147
Trying to replace some pickup teeth on this baler and the slotted head screws are rusted and the slots are bunged up. These are the screws that are in the stripper bands. Any tips to getting them out? thanks
[Reply]   [No Email]
Lee A. Schexnaider
12-06-2012 12:44:10
184.186.71.54
 Re: Advice on rusty slotted head screw removal on a 14 T baler in reply to david1, 12-05-2012 09:05:21
Air chisel used on the ege of the slot should do it.
[Reply]  [No Email]
El Toro
12-06-2012 06:27:38
108.3.143.30
The heat suggested will loosen them. Hal
[Reply]  [No Email]
cannonball
12-06-2012 04:40:49
75.88.13.250
Find a nut big enough to go around screw and weld it to the screw let cool and back out...
[Reply]  [No Email]
ET
12-06-2012 03:57:04
173.86.118.78
Heat the head up till it's red hot. Then let it cool, they should screw right out. The ones on the bottom were the tough ones to get out.
[Reply]  [No Email]
Don-Wi
12-05-2012 19:04:26
75.249.22.110
 Re: Advice on rusty slotted head screw removal on a 14 T ba in reply to david1, 12-05-2012 09:05:21
Weld a nut to the screw just like I would if it were broken off. No biggie.
New flat head cap screws can come with a hex in them for an allen wrench, so they get a better purchase instead of a slot for a flat balde screw driver.
Donovan from Wisconsin
[Reply]  [No Email]
dino in iowa
12-05-2012 18:25:14
75.226.15.187
Harbor Freight impact screwdriver
[Reply]  [No Email]
rusty wheel
12-05-2012 17:10:22
75.180.23.218
I'd soak them overnight with PB Blaster and try a hammer and centerpunch close to the outside of head of the screw.
[Reply]  [No Email]
rusty wheel
12-05-2012 17:10:02
75.180.23.218
[Reply]  [No Email]
Diydave
12-05-2012 16:48:38
96.244.157.254
only takes a second, or 2 more, just to grind the whole head off. Then a pair of vice grips, and back it out.
[Reply]  [No Email]
old
12-05-2012 17:24:27
209.86.226.57
 Re: Advice on rusty slotted head screw removal on a 14 T baler in reply to Diydave, 12-05-2012 16:48:38
But on some of those if you do that then you replace the bigger part due to the fact the nut is welded to the back side of the part so it is get the screw out or buy a $25 part if not more since it has green and yellow paint on it
[Reply]  [No Email]
old
12-05-2012 14:30:32
209.86.226.18
Another thing I just thought about that might work if you can find one is one of those old hammer type impact tools where you hit it and that hit turns the screw driver part and free up the screw
[Reply]  [No Email]
LenND
12-05-2012 17:42:33
74.207.160.118
 Re: Advice on rusty slotted head screw removal on a 14 T baler in reply to old, 12-05-2012 14:30:32
The slide hammer I mentioned is the same thing as you mentioned. I have used it several times for that. The only problem is you need the end small enough to match the screw head. I ground the hammer head down to fit the screw.
[Reply]  [No Email]
old
12-05-2012 17:48:16
209.86.226.57
 Re: Advice on rusty slotted head screw removal on a 14 T baler in reply to LenND, 12-05-2012 17:42:33
Never seen or heard of any type of slide hammer type thing like you say. What I am talking about is maybe 6 inches long and you can change the tips so you can use a socket or a screwdriver tip and you hold it in one hand then hit it with a hammer and the action of the hammer makes the thing twist and also due to the hit forces it down so it hold better then a normal screwdriver would
[Reply]  [No Email]
JRSutton
12-05-2012 18:51:27
75.130.109.233
 Re: Advice on rusty slotted head screw removal on a 14 T baler in reply to old, 12-05-2012 17:48:16
an impact screwdriver - you put it in the slot and smack it with a hammer.
A must have tool.
Doesn't do you much good if the slot's already totally gone - but it would have avoided that problem had you tried it earlier.
[Reply]  [No Email]
Tim(nj)
12-05-2012 18:13:21
67.237.1.234
I have one of those. My father, a retired mechanic/machinist, calls it an 'impact driver.' Not to be confused with an 'impact wrench'.
[Reply]  [No Email]
RayP(MI)
12-05-2012 14:23:53
207.241.137.116
You could try to cut the slots out with a Deemmel and a thin cutoff disk. Then go at them with a proper sized screwdriver blade. How about a impact driver tool? The kind that has a screwdriver bit, and you hit tpo with a hammer?
A little heat may help, and of course your favorite snake oil. Have had good luck with propane torch and candle wax on stubborn threaded things.
My NH actually uses hex head bolts with no problems with hay snagging, etc.
[Reply]  [No Email]
LenND
12-05-2012 12:32:07
74.207.160.118
I took the screws out of the front off my old Case with a slide hammer. Worked good if you can get at all the screws.
[Reply]  [No Email]
dboll
12-05-2012 11:54:53
209.23.168.236
weld a flat washer to them and grab them with a good 10" vise-grip
[Reply]  [No Email]
old
12-05-2012 10:27:22
209.86.226.19
Yep those can be fun to remove at times. A dull chisel and a good hammer then tap to the side so as to drive it off in the same way a screwdriver would turn it might work. Of course heat can help but be careful due to the hay that may be there
[Reply]  [No Email]
cydectin
12-05-2012 09:44:18
69.179.160.226
Right angle grinder with a thin cut off blade to renew slot and a torch to put heat to the nut. Should come right off.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
