TractorLinks.com
Re: two way plow
HoosierHog
12-03-2012 14:08:36
I use an oliver 1850 about 90-95 pro hp. I have seen a 4-16 rollover plow sell here for 3500 I saw a couple jd rollover plows here I n Indiana on tractor house a 3-16 and a 4-16 modle F835 both of them and wanted 1500 and 2000. I just can't justify that kind of money on a plow. I spent 550$ on my 5 bottom Oliver plow, I took off one bottom and I set it on 18in then reset on 16in I can pull it on 5-16 ok 4-18 is ok a bit better then 4-16 I can pull in any ground no matter what. So I left it set as a 4-16.
DeltaRed
12-03-2012 15:36:28
 Re: two way plow in reply to HoosierHog, 12-03-2012 14:08:36
Here,an 1850 is a 3 bottom tractor.3x14/16 would be perfect.That 706 pictured is turboed to 90+ hp.In the heavy ground/sod,3x14 is plenty.On the light soils,it will pull 4x14.See the extra long frame on the 706/3 bot?that is for the 4th bottom.
Brendon-KS
12-03-2012 17:32:55
 Re: two way plow in reply to DeltaRed, 12-03-2012 15:36:28
Growing up in southeast Colorado our neighbor pulled a 4-bottom IH rollover with his Deere 4240 and you could tell it struggled in places. Another neighbor pulled a similar plow with a 5088 FWA and it appeared to be a good match. I worked for a farmer who had a pair of IH 3-bottom rollovers and put one on a 4030 (80hp) and the other on a 4010 with a ~90hp 4020-sized engine. In either case it was about all the tractor wanted.
