Belt for FEO-20 Ferguson Sickle Mower
jacksmad1
New User
I have an Ferguson FEO-20 sickle mower, but not the original belt or a parts manual. Does anyone know the size belt this mower requires? Length and width? I have an operators manual but it does not list the belt size.
Check with an Industrial Belt & Bearing distributor. They should be able to tell you how to measure for a new belt - and then sell you a much better belt than the original equipment belt for a lot less than a dealer will charge you for a belt.
Jack, The FEO-20 was built narrow or wide. Narrow
for use with rear wheel in and wide for wheels
out(as for cultivating) The narrow is p/n 195671m1 (HC 92" outer)and wide is p/n 195672m1
(HC 105") Chuck
(quoted from post at 23:51:14 12/03/12) Jack, The FEO-20 was built narrow or wide. Narrow
(HC 105") Chuck
Thanks Chuck!!
I had seen several references to the wide part number but had not ever seen the narrow one. Thanks for your help! :)
