TractorLinks.com
Re: Welding and turning a damaged shaft
david1
11-29-2012 17:39:25
Its a NH rake axle and the bad place is where the frame bearing attaches to the axle. The axle housing broke and they used a couple muffler clamps to hold it together and they really ate into the axle a place about 4 in wide. I googled info and there is alot of conflicting info on how to weld/build up an axle.
RodInNS
11-30-2012 15:47:48
 Re: Welding and turning a damaged shaft in reply to david1, 11-29-2012 17:39:25
For that... you can probably weld it up decent enough like Don suggested... then grind it reasonably smooth with a flap disc. I'd probably take it a bit under size then use the green Loctite to set it up. Should be OK with that.
Rod
