Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Welding and turning a damaged shaft
Don-Wi
11-29-2012 17:23:25
One thing not mentioned, and lots of guys are making assumptions, but WHERE on the shaft? WHAT rides there? Bearing? Bushing? Sprocket/gear?
In a pinch, it works and if money is tight, by all means do it. Being a machinist I try to do it right if at all possible but even I have had to weld & grind something down in a pinch.
Some guys are ready to condemn a practice, but some times it's all a guy can do to get the equipment back in the field. While I would build it up and spin it in a lathe if at all possible, it's-your equipment...-your budget...-and your time... Do what suits you and gets the job done.
Donovan from Wisconsin
david1
11-29-2012 17:39:25
 Re: Welding and turning a damaged shaft in reply to Don-Wi, 11-29-2012 17:23:25
Its a NH rake axle and the bad place is where the frame bearing attaches to the axle. The axle housing broke and they used a couple muffler clamps to hold it together and they really ate into the axle a place about 4 in wide. I googled info and there is alot of conflicting info on how to weld/build up an axle.
RodInNS
11-30-2012 15:47:48
 Re: Welding and turning a damaged shaft in reply to david1, 11-29-2012 17:39:25
For that... you can probably weld it up decent enough like Don suggested... then grind it reasonably smooth with a flap disc. I'd probably take it a bit under size then use the green Loctite to set it up. Should be OK with that.
Rod
Copyright © 1997-2015 Yesterday's Tractor Co.
