Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Welding and turning a damaged shaft
ihman73
11-27-2012 08:24:33
People might make fun of me but on low speed low stress shafts I have welded up and ground it down close with an angle grinder. It isn't right for every application but works fine in some. We call it "hillbilly machinework".
rustyfarmall
11-27-2012 11:05:13
 Re: Welding and turning a damaged shaft in reply to ihman73, 11-27-2012 08:24:33
An angle grinder is quite often referred to as a "poor man's milling machine"
If there is no great amount of precision required, welding it up and grinding it down is as good a way as any to return a machine to productivity.
dboll
11-27-2012 15:33:14
 Re: Welding and turning a damaged shaft in reply to rustyfarmall, 11-27-2012 11:05:13
no it's not unless your machinery doesn't mean much to you, a pivot pin in a hitch or linkage maybe yes, a shaft that turns or holds a bearing or bushing definately not
david1
11-27-2012 10:23:25
I like the way you think. Would I be better off to get it built up brazing it with a brass rod and filing it down or use an electic rod and grind it.
Stick welding
11-27-2012 12:05:27
 Re: Welding and turning a damaged shaft in reply to david1, 11-27-2012 10:23:25
Don't braze it. It will be too soft and wear out real fast.
SD Pete
11-27-2012 12:03:24
I have done it both ways. My Grinder is much faster than a rusty old file.
