435 J Deere Rd baler
Anonymous-0
I have a 435 J Deere round baler that wouldn't pick up slick or short grass. I solved that problem by welding a bead of 7018 welding rod along the square flat bars from one end to the other on all of the bars attached to the pick up roller. Weld the bead in a zig zag pattern all along the bars to create a rough texture and this will solve the problem. You will be very happy with your 435 or 535 baler again. Thanks.
JD advised dealer service managers back in the "early 90's" when problems arose starting a bale to weld a bead on the "leading edge" of the rectangular bars of the starter roller.
