| Implement Alley Discussion Forum |
Topic: Re: Demco sprayer
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| JD Seller
11-25-2012 17:40:56
208.126.196.144
Mikein Ky you don't understand what you have bought. The PTO centrifugal pump is to agitate the spray solution while you are setting still. The ground drive pump meters the amount you want per acre within a speed range. So if you slow down or speed up the gallons per acre stays the same. The pressure and flow changes to match your ground speed. You have to go fast enough to make the nozzles work and slow enough that the flow does not max out. Usually a range between 3-10 MPH. If you have a regular sprayer that you have to spray at a certain speed and pressure. You put more gallons per acre on when you slow down and fewer gallons per acre when you speed up. The ground drive pump is a better system if it is working correctly. The PTO pump should just be for agitation only. Which is good as well because the spray solution will be kept mixed better. Some regular sprayer pumps do not have enough flow to agitate much when you are spraying. |
| MikeinKy
11-26-2012 18:04:09
184.45.29.210
Re: Demco sprayer in reply to JD Seller, 11-25-2012 17:40:56
| Thanks for the replies. I thought that was the way it was supposed to work. You are right about the amount applied. I sometimes waste a lot with a pto pump. Maybe it is set up this way for better accuracy. I wanted one like this for awhile. usually they go for 3000 to $5000 around here. I got this at auction for $1000 wit 600 gal tank tandem axles, 45 ft boom and foam markers. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
