TractorLinks.com
Re: Planting soybeens with JD 7000
dboll
11-24-2012 06:35:52
if you fall kill alfalfa the ground will mellow out over the winter making no-till alot easier than spring killed, too late if you are in a northern state, find some Kinze units,they are worth it, you could probably locate some on Craigslist, just make sure the plates are not worn out, four down pressure springs on the parralel links will do alot,originally the 7000's usually had two per row, Shoup has the kits, make sure the openers are 14.5 to 15 inches in diameter
