Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: CASE plow hitch ....to a hitch pin.
[Return to Forum]
Greenfrog
11-20-2012 16:35:26
206.71.203.66
I restored a nice 3 bottom CASE plow. As you know the hitch is a spring loaded hook type trip hitch. That is fine, however for towing down the highway for show and parade, there is a lot of flip-flop in the twist clevis. I wired it in also. Just want to make it road ready, I am thinking about modifying it to hitch -pin type.. for safety. I don't plan to use it for plowing, but want to be able to change it back if neeeded.
Any suggestions on the design for this?
[Reply]   [No Email]
jon f mn
11-21-2012 19:51:14
70.194.64.8
Re: CASE plow hitch ....to a hitch pin. in reply to Greenfrog, 11-20-2012 16:35:26
Just make a clevis hitch to bolt on your tractor drawbar like the big tractors have so you just drop a pin through. Thats how I pull my 4-16's case. no swaying that way. I just got some 3/4 thick material, cut it in 3 pieces. one to bolt to the drawbar's second hole. One to weld on to raise it about 3". and one to weld back for the pin hole. Then a couple of triangle braces to hold it together and it works great.
  [Reply]  [No Email]
LA in WI
11-21-2012 07:13:54
50.50.87.195
I had same problem with my IH trailer plow. I raised the handles up (that action lowers the plow) until the moldboards were only 2" off the road surface. That changes the angle of the rear wheel and the plow will not sway...even with tractor in road gear. When you get to the show, just lower handles to increase the clearance under the moldboards.
I suggest to not pull plow with a truck; things can go wrong real fast with that plow when doing that. Besides, it's more fun driving the tractor anyway!
LA in WI
  [Reply]  [No Email]
casecollectorsc
11-20-2012 18:50:55
64.33.231.126
Some of the newer Case plows you can lower the levers and the tail wheel will be locked in stationary position and won't sway. Not sayin you can go 40 mph, buy it does help.
  [Reply]  [No Email]
Greenfrog
11-20-2012 20:43:35
206.71.203.66
Re: CASE plow hitch ....to a hitch pin. in reply to casecollectorsc, 11-20-2012 18:50:55
This one locks the tail wheel, but the shares also go down. I am just towing it down a blacktop for about 2 miles and then on a bit of gravel to the county fair where the old time area has a display..
  [Reply]  [No Email]
DeltaRed
11-20-2012 17:49:23
67.6.219.50
Un bolt the clevis assy from the frame/tounge.Then 'manufacture' a pinhitch assy,then bolt it to the frame useing the same holes.Fresh paint and good workmanship and no will ever know....
  [Reply]  [No Email]
Greenfrog
11-20-2012 20:40:46
206.71.203.66
Re: CASE plow hitch ....to a hitch pin. in reply to DeltaRed, 11-20-2012 17:49:23
Yes, that is what I am thinking about doing. Have to find a piece of iron.
  [Reply]  [No Email]
acken fromwisc
11-20-2012 17:37:46
68.114.243.42
From past experience, I would not try to tow a plow down the road, maybe less than 4 miles an hour. The rear wheel will cause the plow to sway back and forth from side to side.
  [Reply]  [No Email]
Greenfrog
11-20-2012 20:47:13
206.71.203.66
Re: CASE plow hitch ....to a hitch pin. in reply to acken fromwisc, 11-20-2012 17:37:46
Yes, I found that out! I am towing behind a tractor or SUV just to the county fair a few miles away...
I am just trying to get rrid of the flip-flop noise of the sloppy hook hitch....quite noisy inside of my vehicle!!
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
