IH 56 corn planter 12 r 20, 10 r 24?
This message is a reply to an archived post by meanmoline on August 25, 2012 at 18:36:29.
The original subject was "IH 56 corn planter 12 r 20, 10 r 24?".
Hello! Back again with harvest out of the way and the shop nearly cleaned ou, I have decided to start this project. Has any one tried this before? Still looking at wheel configurations. I think i can drive the shafts for fertilizer and planting units with common roller chain off the narrow hubs.I found 2 and might try to make 2 more with gears on them. I did realise I need new or good used fertilizer augers, if any one has a source for those augers that came in the steel fretilizer hoppers please let me know, I will need 4 augers from 6 row planters.
What are you planting in 20 inch rows with a IH 56?
If it is corn you would increase your yeilds more by going with a newer planter on 30 inch rows that has better seed placement than trying to use that old planter in 20" rows.
If it is beans it may work okay.
Gary
I did it this way with an old Oliver 540, but didn't bother with the fertilizer part. Maybe, you could fab'd a shaft for to replace the tensioner, you might get it to drive the fert auger. I see no reason you couldn't have the two driving a common shaft. Well as long as you are not doing sharp turns. Just watch the direction of the drive system.
I concur with Gary, why would you use that old of a planter which at the time wasn't even highly regarded? A grain drill is as precise as that unit with depth and seed placement. Random is the key word!
Start with a Deere 7100 and you will never regret it! Cheap-Easy to get parts-SHOUP.You still can't beat the FINGER unit!
