TractorLinks.com
Re: Mowing hay
Leroy
11-19-2012 05:42:24
Unless you have a selfpropelled unit or a pulltype that you can swing from the tractor seat while you are turning at each end and cut all the field from same side then the only sencible way is round and round as without that you would be spending a lot of time and fuel wasted to travel across the ends and unless you waited to mow the rest of the field till you had the outside rounds baled they would be ruined from driving on them and even if you did that then you would be doing damage to the crop for later cuttings. This is all with a mower that only cuts on one side and unless you are a big time operator you usually will not have that hydraswing or selfpropeled unit.
