TractorLinks.com
Re: jd grain drill
Briar Hill Brittanys
11-18-2012 19:37:21
I've rebuilt several of those power lifts on JD/VB FB and FB-A drills. In every one, the throw out spring has been either broken, missing, or not attached. Also, the drive roller has been rusted up on the drive link. The drive link is the curved, arm looking piece that pivots inside the lift housing. The roller slips on a small shaft, and should rotate, riding in the scalloped inside edge of the outer lift housing. The spring WAS still available from John Deere.....Throw Out Spring, Part # S 918 M, . It's a pretty stout spring. Disassemble that dude, clean the decades old, hardened grease and dirt out of it. Replace the spring (if needed), polish the drive roller with a wire wheel, grease the mating surfaces with a good grease, and reassemble. I've got a copy of the parts breakdown on PDF if you need a page or two to help. The lifts are very reliable. I drilled about 18 acres of wheat and rye with ZERO malfunctions since I rebuilt it last year. The drill was channeled from a 17 to 8 X 7. That's a lot of ups and downs, 56" at a time. HTH Mark
This post was edited by Briar Hill Brittanys at 19:47:26 11/18/12 2 times.
ronnie tucker tn logger
11-19-2012 06:41:22
 Re: jd grain drill in reply to Briar Hill Brittanys, 11-18-2012 19:37:21
thank you for the reply.the parts break down would be helpful.
