JD 55 A-B-H Trip Plow
Anonymous-0
I"m having trouble removing the left wheel in order to replace the tire. Any help is appreciated. Thanks. Mark M. Minnesota
Unless you know what you are doing, you will break the CAST HUB. It is on a TAPPER SHAFT, *TIGHT* can be knocked off if you know how or save your self some heart ache and change the tire with the rim still mounted, not that big a deal.
Hello, I need a little more help. I am reinstalling the wheel/lift. I cleaned up the parts but can't get the lift gear on the axle far enough (after installing 3 axel washers) to insert the pin. I assume the notches on the lift gear/cam face toward the plow, correct? I appreciate your help as I am a rookie with this repair. Thanks. Mark M Minnesota
Thanks. Can you help with reinstall question. I can't seem to get the wheel/trip gear, cam or ? on far enough to reinsert the pin throughg the axle. I have been looking for a diagram of the trip wheel mechanism but can't seem to locate on on line. thanks. Mark M Minnesota
