TractorLinks.com
Re: JD 55 A-B-H Trip Plow
Carlyle Hoffman
11-12-2012 13:04:57
Unless you know what you are doing, you will break the CAST HUB. It is on a TAPPER SHAFT, *TIGHT* can be knocked off if you know how or save your self some heart ache and change the tire with the rim still mounted, not that big a deal.
mollymarmink
11-14-2012 06:30:26
 Re: JD 55 A-B-H Trip Plow in reply to Carlyle Hoffman, 11-12-2012 13:04:57
Thanks. Can you help with reinstall question. I can't seem to get the wheel/trip gear, cam or ? on far enough to reinsert the pin throughg the axle. I have been looking for a diagram of the trip wheel mechanism but can't seem to locate on on line. thanks. Mark M Minnesota
mollymarmink
11-13-2012 16:40:31
Hello, I need a little more help. I am reinstalling the wheel/lift. I cleaned up the parts but can't get the lift gear on the axle far enough (after installing 3 axel washers) to insert the pin. I assume the notches on the lift gear/cam face toward the plow, correct? I appreciate your help as I am a rookie with this repair. Thanks. Mark M Minnesota
