TractorLinks.com
Re: Bought an IH 37 square baler today. Cheap
Mark Robke
11-11-2012 16:55:44
I have had mine for 16(?) yrs. Replaced a few brgs, pto u jt. Usualy now a few hundred bales a yr. Used to do about 1500 a yr. Works ok,but sometimes bales are not same length; sometimes never misses a knot , other times misses a few in a 100. Ok for a small opertion. I have put out nearly 200 in an hr in heavy hay, but now mostly use it for 2nd,3rd cutting alfalfa.
From your picsit appears to have origional tires on it. Could you tell me the sizes? Mine has car tire on it, and does not sit perfectly level.THANKS,MARK.
JD Seller
11-11-2012 20:13:15
 Re: Bought an IH 37 square baler today. Cheap in reply to Mark Robke, 11-11-2012 16:55:44
I did not look on the baler but I did get the original Operators book. It lists the Left tire as a 6.40 x 15 6-ply implement tire, 40 psi.
The right tire as a 5.00 x 15 4-ply implement tire, 28 psi.
If you need anything else let me know.
