3pt Grain Drill
Anonymous-0
Has anyone converted a John Deere 8ft FB grain drill to 3pt would like to do it my tractor should handle it a Int.656. If anyone has done this please let me know the pros and cons.
Thanks David
first question is why? It is possible to do, you'd simply remove the tongue and attach an a-frame for 3-point in its place. I don't know if you'd still want a way to disengage the seeder drive or not. That might get tricky if it's a clutch lift. On con I can think of is that the drill won't follow the lay of the land as well on 3-point. Front of the tractor goes down, drill lifts up a little, back of the tractor goes down, drill digs a little deeper. Another concern I have is if the frame of an FB is rugged enough to pick up and put down repeatedly without failing.
What would be the difference between mine and a TRUE 3pt drill other then the cost. I just think it would work better on my small odd shape field not so much turning and running over the seeded ground
I understand the thought for getting into corners to plant, but seems it would have more negatives than positives in the big scheme of things.
Forgetting it in the ground and turning too sharp would be devistating to one not designed for 3pt use, the side-load would make a lot of rumples....
--->Paul
Frame would not stand ont time lifting if boxes filled and you would still need the wheels for depth control plus driving the seeding mechanisem. There is a reason the AC snap coupler drills did not go over and they were designed as a mounted drill.
I have a 6' IH drill thats 3pt.works ok,you must lift at every end,or every corner if going 'round n round'.Leave it in gear.'Lifted' with an H farmall.
Thanks for the feedback. Are there any low budget 3pt drills out there they must not be very popular.I would need to leave it down to go around slow curves.
I've never seen those sort of wheels under an older IHC drill up here, is that something that came with it, or cobbled together from a different drill?
What drives the drill meters, those thin wheels?
Actually, I don't see any seed openning disks, or seed tubes?????? Really? Does a drill work without those in your climate, or is it just not showing up in the pics?
Interesting.
--->Paul
That is a 'press drill'.The press wheels were moved from behind to underneath.You are observant!The tubes and disk openers are gone.they were removed because they were all broken,missing,etc.The thin wheels turn the metering shaft.Since we irrigate everything,I simply let the seed fall,the 'harrow,coveres.They I make corrugetes/water'marks',which covers the seed.This was a horse drill,them converted to a 'tractor' drill,then to a 3 point.Steve
Marliss and Tye are two companies that made quite a few smaller 3-point drills 20-30 years ago. . . but neither is a current production brand. AGCO still has some parts for Tye, and Sukup made the Marliss line until recently, so parts are still available, but for how long?
I noticed your very dry ground, in other pics too.
Irrigation, that would make your drill work just fine, makes perfect sense then.
You ever plant beans with it, or only small grains? I've not been a fan of drilled beans for me, but some do it around here.
--->Paul
We only plant pinto beans,not soys.No soys are grown in Co.Pintos are planted in (30") rows.Only grain is planted with a drill.In fact,most grain is 'spread/brodcast with a fert spreader.We then cover with a roller harrow/culti- mulcher,then 'marked'.
