Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: john deere 1710A disk chisel bouncing
littleschnebs
11-10-2012 22:25:16
We have had this chisel for more than ten years and it has always done it. The type of ground definitly makes a difference. This morning it was pulling like a dream at 6.5 mph. On the other side of the hill it was bouncing like no other at 3.5 mph. My boss has a 712 or 714 that has 9 shanks and it NEVER bounces. I wonder what the difference is? I"m not doubting that we pull it too fast like you said it"s not designed to be pulled over 5 mph. I know that is definitly the problem sometimes. But other times we have to go 3 mph so it doesn"t bounce at all. We have tried to level it, but maybe we didn"t do it right? Is there a secret to setting everything right?? thanks!
JD Seller
11-11-2012 20:19:08
 Re: john deere 1710A disk chisel bouncing in reply to littleschnebs, 11-10-2012 22:25:16
I always set the level when the machine is in the ground. Usually on a chisel plow you will set it about an inch higher in the front. The draft action of the chisel will rock it forward just a little when you pull it.
I am willing to bet that it is the shank springs that are causing the bounce. The 712 and 714 have a heavier spring setup on them.
If you can find a set of depth wheels off another chisel then you may try them. The 1710A maybe sucking in too far and then bouncing when it comes back to the set depth.
