JD Model 5 power mower parts?
Does anyone have this P/N for the quick hitch on a #5?
Z8887H superseded by H22751 "pad, rubber"
These are #3 on page 50-1 in the parts manual.
Looking for 4 total.
Thanks
I checked with him, he has one in stock, so I figured I'd check here to see if anyone had a couple of pair stashed some where that they could part with, or a possible alternative.
Without hunting up a parts manual I would guess you are talking about the rubber pad in the clamp for the quick hitch and if that is what you are talking about just make them yourself out of the sidewall of an old tire. might have to use a 6 ply rating to get thick enough or on one side just put in two layers of rubber sidewall, whatever it takes for the clamp to tighten down on. and cheapest fix you can get.
Radiator hose works well.
<a href="http://s200.beta.photobucket.com/user/jameslloydhowell/library/John%20Deere%20Equipment/Power%20Mower" target="_blank">
TM-20.jpg" width="650" border="0" alt="Photobucket"
</a>
I have seen them made out of radiator hose. They are only $5.89 each from JD. Your dealer can order them on his bi-weekly stock order for not extra charge. I would jut get the factory one and be done with it.
