TractorLinks.com
Re: NH 851 Round Baler
old
11-04-2012 16:03:16
You can still buy the manuals from New Holland I know because I did so for my 850. As for getting it ready grease it up oil the chains etc and read the manual. When baling with one you do need to drive almost as if your drunk as in go side to side over the windrows so as to fill the whole bale area or you can/will break things or bend the bars etc.
T in KY
11-04-2012 16:35:06
 Re: NH 851 Round Baler in reply to old, 11-04-2012 16:03:16
Great help, I have heard to NOT make large windrolls and drive fairly slow with good RPM. What about the auto tie? It does not have any wiring exposed (I.E. a plug, etc.)
old
11-04-2012 18:06:21
 Re: NH 851 Round Baler in reply to T in KY, 11-04-2012 16:35:06
On the round baler like the 850 or 851 you want nice size windrows and or put 2 side by side so you do not have to driver back and forth across the windrow. As for speed you do not want to go to slow or you get a bale the is extra heavy and very hard to put a bale spike in, learned that the hard way when I first got my 850 and could not lift the bales with my loader tractor due to how heavy they where. I now run in 3rd gear with my Oliver Super 88 and that is just about right for a nice bale. As for auto tie I can not help you with that the 850 does not have that
IaGary
11-04-2012 17:41:44
You want your windrow as big or bigger than for a square baler.
After you get the bale started you will also drive faster than square baling or the baler will grind up the hay faster than you feed it in.
I use to run 4 MPH in windrows that barely fit under the front axle of the tractor.
Gary
