| Implement Alley Discussion Forum |
Topic: Little Genius Plow
[Return to Forum]
| Author |
[Modern View]
| Mark Poss
11-04-2012 04:20:39
173.25.60.148
Can someone tell me the correct way to set up the hitch on a little genius plow to pull behind a 37 John Deere A I have the plow manual but it only shows diagrams for older Farmalls. The plow is a two bottom with 14" shares. Thanks for your time, Mark. |
[Reply] [No Email] | |
| mkirsch
11-05-2012 05:43:12
64.80.110.75
Re: Little Genius Plow in reply to Mark Poss, 11-04-2012 04:20:39
| Why would the setup be any different for a JD vs. an IH?
All it should be is distance from the inside of the tractor's right rear wheel to the drawbar, and distance from the inside of the plow furrow wheel to the center of the plow. A few inches either way won't really make much difference. |
| Leroy
11-05-2012 09:34:57
69.88.205.38
Re: Little Genius Plow in reply to mkirsch, 11-05-2012 05:43:12
| Difference is the Ih is probably a wide tread in that the wheela are permantly set in the cultivating position for 2 40" rows or 80" wheel tread, more if the tractor has the 28" rubber on and can not be narrowed down like the Deere to about a 56" wheel tread. |
| Bret4207
11-04-2012 15:28:52
64.19.90.196
Re: Little Genius Plow in reply to Crazy Red Power in SE-WI, 11-04-2012 04:20:39
| Quoting Removed, click Modern View to see
Hey Ron- THANKS!!! That manual was just what I've been looking for for some time. |
| Ron W
11-04-2012 08:40:17
24.247.83.82
| | Check this out...a manual on the lil genius plows http://ia700409.us.archive.org/13/items/cu31924003310962/cu31924003310962.pdf |
| Carlyle Hoffman
11-04-2012 04:57:10
74.71.111.250
| First set your plow draw bar (center) 23",s from the furrow wall, after you have made a short test furrow. Now set your tractor draw bar the same demention from the inside of your right rear tractor wheel, wheel will probably have to be moved in. When you make your first pass , check to see that your front coulter is cutting just 14",s from the furrow wall.You can change that by shorting or lengthening the plow hitch draw bar brace.From the back of the plow, your right hand lever sets your leveling and the other your depth ,if no hyd. cylinder is being used, meaning ground lift plow.Your coulters should be set 3/8s to 1/2" to the left of you points and coulter axel 2",s ahead of the points , if your bolt holes allow this to be done. Have fun. |
| Carlyle Hoffman
11-04-2012 05:01:48
74.71.111.250
Re: Little Genius Plow in reply to Carlyle Hoffman, 11-04-2012 04:57:10
| Sorry, to clarify set your tractor right rear wheel 23",s from you tractor draw bar being (centered) on the tractor. , Sorry for the miss explanation, i goofed up. I knew what i wanted to say, just did not come out that way.. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
