Kuhn GMD 800 Length Alteration
Anonymous-0
I have a Kuhn GMD 800 HD II, 10 ft cut. At the end of this summer, on the end of the bar the bolts at the last top hat worked loose and cracked the tip of the bar. Could I cut the end of the bar, weld/seal the end and use the Kuhn as a 9 ft mower? Has anyone heard or seen this done? Thanks
The outermost knife hat must rotate counterclockwise as viewed from the top, otherwise you are wasting your time.
on a nine ft the first 2 disc turn clockwise....then ccw and cw to the end one, as said below, the last one is ccw, can you do it..I would say no....
Why try to reinvent the wheel? As rick noted... The outer disc must turn counterclockwise to pull hay from the edge of the cut. Doesn't work otherwise. Weld up the cracks... Very carefully... And move on.
Rod
