Anonymous-0
I am thinking along the lines of a miniture air dryer setup for corn. Corn would be used for a corn stove. Something along the lines of a steel 50 gal drum with a heavy duty fan ducted into the bottom side. Also need to make a false floor. I would set this up on a buggy of sort so I can move it outside on nice days. What I need to know is how dry can I get corn with just outside air, I am aiming for 13%. Also thinking I could set this by the stove in the garage during winter and dry some that way. Would the excess moisture be too much for inside the garage? I use about a hunder + bushels a yr for heat. I normally get some 15% out of the field each yr but this yr looks doughtfull. They say Hurricane Sandra is headed here to eastern Pa.
