EP-0 Grease
SGF
I recently bought a 6' Kodiak mower. The manual says to use EP-0 grease in the gearbox. So far all I get in local stores when I ask for it is a blank stare. I know the EP series of grease/oils have special shear properties but is there a more available "correct" alternative or is this stuff that hard to find?
Hello, what you need is John Deere Corn Head grease. It has the NLGI rating of 0 (ep-0) I have a tube in the garage. I used it for the steering box on my tractor with great results. It is made for steering boxes and gear boxes. It will not leak out of old seals like gear oil.
The following table shows the NLGI classification and compares each grade with household products of similar consistency.
NLGI consistency numbers:
000 445-475 fluid cooking oil
00 400-430 semi-fluid apple sauce
0 355-385 very soft brown mustard
1 310-340 soft tomato paste
2 265-295 "normal" grease peanut butter
3 220-250 firm vegetable shortening
4 175-205 very firm frozen yogurt
5 130-160 hard smooth pate
6 85-115 very hard cheddar cheese
You'll have to find someone who sells it in smaller quantities, I can source it from a lube supplier, but you have to get a 5 gallon pail, book on my old Rhino SE-6 calls for the same, I use a lucas 90wt if I recall correctly, would have to look in the garage. I don't see any 0 grease on the shelf, given the small quantity the gearbox takes, I just went with the next best thing. It might be a tad more viscous, it does not leak through the seals, gear box don't get hot either, just slightly warm.
I also use EP-0 grease in my NI 5209 disc mower conditioner. I found the "stuff" at my AGCO dealer and Tractor Supply, but had to search a bit. A small tube tops off all my 5209 pods. I used some high grade grease one year but I was surprised to find that my 5209 pods heated up a bit more, especially the two pods that have to sling the grass for the far left and far right pods.
yes the JD corn head grease is NGLI-0 polyurea base. Gearbox on my CIH 8340 calls for ep-0 litium soap base. similar properties, but distinctly different.
• Manufacturer Lubricant
• Amoco Oil Co. - Rykon Grease #0 EP
• BP Oil Co.- Energrease LS-EP0
• Cheron U.S.A., Inc. -Dura-Lith EP0
• Citgo Petrol-Premium Lithium Grease EP0
• Conoco Inc. -EP Conolith Grease #0
• Exxon Company U.S.A. Lidok EP0
• Kendall Refining Co.-Lithium Grease L-406
• Mobil Oil Corp. -Mobilux EP0
• Petro-Canada-Multipurpose Lotemp EPGrease
• Shell Oil Co. -Alvania EP Grease RO
• Shell Canada LTD -Alvania Grease EPW
• Sun Oil Co. -Sun Prestige 740 EP
• Texaco Lubricants-Multifak EP0
• Unocal 76 (East & West) Unoba EP0
