drum mower blades that last longer?
Loren
Got a real old Lely drum mower this spring and sure am glad I did. But, I do contract haying for one couple on 40ac. and the property surely has gopher problems. 3 sets or flips of the blades on that place this year. Is there a tougher blade offered by some companies or are they all relatively soft?
They have to be kind of soft or they will just break off. I had some that where made in Germany. They where made out of harder material. They worked great in flat clean hay ground. If you got into rough ground, where they might hit the least little thing they would break off.
That's the beauty of a drum mower, 3 blades per drum head, and you get 2 uses outta a blade that costs about a dollar a piece. It doesn't pay to make a separate hardened blade. Just buy a big box o blades, and go to work. It only takes maybe 10 minutes to change out a set!
SFI sells a box of 25 double sided for $25. By the time you need to reverse the blades, the blade is jammed up with cuttings which need to be cleaned out anyway so changing the blade (around) just makes cleanup easier. I don't know where they are made.
Mark
