Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Auger downspout
JDseller
10-19-2012 19:29:01
Take four or five five gallon buckets and cut the bottoms off them. Also remove the handles. Then take two pieces of 1/4 inch chain about five feet long. Take the first bucket and bolt the chain to each side with about two feet of slack chain above the bucket. Then take a second bucket and slide it up into the first bucket with about 4-5 inches of over lap. Just keep adding and bolting buckets until the string of buckets are as long as you need them.
Then on your auger you can slide the first bucket over the factory spout. Then just bolt the chains together up over the top of the auger tube. So you end up with a deflector spout that will hang straight down regardless of the angle of the auger. Plus you can let the auger down a little and the buckets will just slide into each other and adjust to the length you need.
Cost ten foot or so of 1/4 inch chain, a few used five gallon buckets and some bolts.
The picture shows a factory made one using flat straps rather than chain. I like the chain better as it will give side ways as well as length ways.
super99
10-20-2012 03:45:54
 Re: Auger downspout in reply to JDseller, 10-19-2012 19:29:01
Thanks, never thought of that.
Angle Iron
10-20-2012 05:04:53
 Re: Auger downspout in reply to super99, 10-20-2012 03:45:54
Get some cheap spray paint to protect from sun damage, they will not get brittle as fast.
