Clutch Facing Material???
Hello-
I am trying to find if someone has a source for reasonably priced clutch facing for balers. I have an IH mccormick model 45 baler. I need to replace the friction slip clutch facing that is on the flywheel. Original part number was 30718D. Can't find this anymore.
The dimensions of the facing are 9" O.D.x 5 5/8" I.D. x 9/64" thick. Can anyone verify if this facing was used on other implements or tractors? Thanks!
Jesse
Try to find a clutch shop near you that relines
brake shoes and clutches. Also if you do find
somewhere like this, ask for a modern, non-asbestos
clutch material. good luck.
You can buy clutch/brake material in the size you
want from Rusco-X Materials, Co. Inc in
Connecticut. (800) 550-7413. The stuff they sell
is non-asbestos. I have had good service from
them.
check with JD, I found facings for my 200 Case baler there for alot less than Case wanted, Weasler made the slip clutches for IH, jd, Case ect.
Check out HEDGEPETH SUPPLY
1406 HEDGEPETH ROAD
CANMER KY 42722
PHONE link_disallowed
I posted here for clutch discs for my Ford 532 back in June 08 and received the following reply: "call me at link_disallowed ask for larry we sell slip clutch disks for 6-12 dollars each." I ended up not needing them so never called him. May be worth a call.
Thanks for all the help everyone on finding clutch facings for my baler. I did a search on Ebay and found a NOS set of clutch facings for a 1936 Oldsmobile car for $10.00. They are the exact dimensions as my baler facings. I just have to drill some new holes in the plate the facing attaches to and take it to a guy I know who has a rivet machine. Also, does anyone have any thoughts on some sort of adhesive to attach the facings to the plate instead of rivets? Thanks!
Jesse
