Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
8ft disc leaves humps
rick2 in ohio
10-14-2012 16:06:07
i noticed last spring my 8ft 3-point massey disc leaves humps about 4 ft wide about 2 foot apart as i go acroos the field would a harrow help keep everything level.
RICK
Tx Jim
10-19-2012 04:09:19
 Re: 8ft disc leaves humps in reply to chuck41, 10-14-2012 16:06:07
Need to lower rear gangs(change level fore to aft) some to throw more soil or possibly increase ground speed. Also increasing the angle of rear gangs could help fill the valley.
OH - 961
10-18-2012 14:12:43
 Re: 8ft disc leaves humps in reply to Bryant Baecht, 10-14-2012 16:06:07
Sounds like you need to angle the rear gang a bit more to throw more of the dirt back toward the center.
Also check level front-to-back to see if the front gang is digging in deeper and throwing more dirt than the rear gang.
Are the discs on the rear worn down more than the front discs or are they pretty much equal? Just some things to look for.
Myron
rick165
10-18-2012 06:11:22
 Re: 8ft disc leaves humps in reply to rick2 in ohio, 10-14-2012 16:06:07
sorry for not getting back to all of you i been very busy at work.is is a double gang and it leaves the valley in the center down the middle of the disc.
RICK
OH - 961
10-15-2012 15:33:06
 Re: 8ft disc leaves humps in reply to Strikefalcon, 10-14-2012 16:06:07
I'm not sure from your description where the humps are. Do you mean that it leaves a ridge behind the disc in the middle of the pass?
If it is leaving a low area or a ridge behind the disc, the angle of the rear gang needs to be adjusted, or maybe both front and rear gangs so they equal out.
Myron
mazemeister
10-15-2012 04:24:26
leveling front to back, rankness adjustments, uneven wear, ground speed, depth, gang spacing, proper overlap one pass to the next...
a few places to start :)
paul
10-14-2012 19:47:11
Disks will do that, adjusting the disk properly (more art than science, some models you can't get perfect....) will do more for you than a harrow.
Describe the disk better, as the other person asks, single or double gang, and so on.
--->Paul
dmiller
10-14-2012 16:26:16
is it a single gang or double gang? Has it been leveled if it is a double gang?
Copyright © 1997-2015 Yesterday's Tractor Co.
