Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: bearcat flail chopper
[Return to Forum]
Finnbair2020
10-10-2012 14:42:51
70.16.207.75
I have a bearcat 6 foot flail chopper. I seem to be going through a lot of shear bolts at the flywheel/clutch that is next to the gearbox. I'm not sure why-- sometimes it's running fine and when I turn off the PTO, it snaps a shearbolt-- sometimes one breaks when I start out. They are quite a pain to put in-- the two parts of the flywheel are very difficult to match up properly. I'm tempted to get a stronger bolt...
[Reply]   [No Email]
jon f mn
10-10-2012 20:33:11
70.195.6.63
 Re: bearcat flail chopper in reply to Finnbair2020, 10-10-2012 14:42:51
Also check the bolt holes for wear. My baler is a problem too, but I can see that the bolt holes vave a gouge in them from using too soft bolts. I will need to build it up again for next year.
[Reply]  [No Email]
karl f
10-10-2012 20:12:20
172.163.26.103
if it"s a 72a like we had, I seem to recall it had an over-running clutch on the gearbox input, which should alleviate shut down driveline stresses. Also the gearbox has a bunch of shims under it to align it perfectly to the blower shaft--if the blower has been adjusted (if it is adjustable) you may need to re align the gear box. There is a double roller-chain coupler for some flex, but I seem to recall the gearbox had to be aligned fairly square to the blower shaft anyway. No matter what tractor, we idled them way low and then engaged the PTO and brought the machine up to speed. The one time we didn"t, the gearbox became shrapnel, even with the slip clutch and shearbolt for protection. Make sure there aren"t any bearings out and the shafts spin true. the shearbolt flanges may need to come apart and be cleaned and inspected to make sure they move freely to seat squarely together.
good luck
karl f
[Reply]  [No Email]
BushogPapa
10-10-2012 16:40:42
173.88.51.117
I believe I would be looking either at the Gearbox or under it for signs of anything striking under the mower..
It shouldn't be shearing the pins..
Does your tractor have a strong PTO Brake that might cause this..?
Ron..
[Reply]  [No Email]
Dick2
10-10-2012 15:53:32
174.19.205.113
If you are using a common Grade 2 bolt, you could try a Grade 5 bolt before you put in a Grade 8 bolt. It might help if you slow down the chopper as slow as you can before disengaging the clutch. It appears that the momentum of the chopper may be creating a backlash on the shear bolt.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
